Pls help,I tried to access another system on my network with the IP add given out to the system by dhcp but couldnt get through. I even try to ping the IP in my winbox but the reply i got is timeout.Even the machine on which I open the winbox,its IP also timeout when I tried to ping.Its only 192.168.0.1 that is responding when pinged.
Somebody Pls, Help ![]()
You aren’t providing enough information. What are you trying to do? Is this a wireless connection? How are you trying to access the “other system”? RDP, vnc??? What are your firewall settings? Have you tried doing a ARP ping?
Thanks Netrat, I tried to access a system on my network (LAN) with its IP.When I opened my network palces I type the IP of the machine in address bar but no reply. I have RB433 on my network,I hv chcked the firewall where I disable Protect Lan in webbox
I then opened winbox and try to ping the IP but no reply.
