i have mikrotik 2.9.27 os
and i have 2 wan "2 ISP" ADSL1 & ADSL2
I want to used ADSL1 for browser web
and ADSL2 to Download file
help me to configer it
may/28/2009 03:48:50 by RouterOS 2.9.27
/ interface ethernet
set LOCAL name="LOCAL" mtu=1500 mac-address=00:01:2E:0A:65:B6 arp=reply-only disable-running-check=yes auto-negotiation=yes full-duplex=yes
cable-settings=default speed=100Mbps comment="" disabled=no
set WLAN1 name="WLAN1" mtu=1500 mac-address=00:00:E8:11:18:11 arp=enabled disable-running-check=yes auto-negotiation=yes full-duplex=yes
set WLAN2 name="WLAN2" mtu=1500 mac-address=00:02:B3:8D:FF:37 arp=enabled disable-running-check=yes auto-negotiation=yes full-duplex=yes
/ interface wireless security-profiles
set default name="default" mode=none authentication-types="" unicast-ciphers="" group-ciphers="" wpa-pre-shared-key="" wpa2-pre-shared-key=""
eap-methods=passthrough tls-mode=no-certificates tls-certificate=none static-algo-0=none static-key-0="" static-algo-1=none static-key-1=""
static-algo-2=none static-key-2="" static-algo-3=none static-key-3="" static-transmit-key=key-0 static-sta-private-algo=none static-sta-private-key=""
radius-mac-authentication=no group-key-update=5m
/ interface wireless align
set frame-size=300 active-mode=yes receive-all=no audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 ssid-all=no frames-per-second=25 audio-min=-100
audio-max=-20
/ interface wireless snooper
set multiple-channels=yes channel-time=200ms receive-errors=no
/ interface wireless sniffer
set multiple-channels=no channel-time=200ms only-headers=no receive-errors=no memory-limit=10 file-name="" file-limit=10 streaming-enabled=no
streaming-server=0.0.0.0 streaming-max-rate=0
/ interface bridge broute
add chain=brouting in-interface=LOCAL in-bridge=(unknown) action=accept comment="" disabled=no
/ interface l2tp-server server
set enabled=no max-mtu=1460 max-mru=1460 authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption
/ interface pppoe-server server
add service-name="aa" interface=LOCAL max-mtu=1488 max-mru=1488 authentication=pap,chap,mschap1,mschap2 keepalive-timeout=10 one-session-per-host=no
max-sessions=0 default-profile=default disabled=yes
add service-name="service1" interface=LOCAL max-mtu=1488 max-mru=1488 authentication=pap,chap,mschap1,mschap2 keepalive-timeout=10 one-session-per-host=no
/ interface pptp-server server
set enabled=no max-mtu=1460 max-mru=1460 authentication=mschap1,mschap2 keepalive-timeout=30 default-profile=default-encryption
[admin@DGGAT] interface>
