hi to all
i still have the same problem in cashe MT 2.9.2
i put a new rule in firewall nat to redirect the port 80 to 3128 to make the cashe work but still the problem
the real problem when i put the new rule it’s work good but when restart the MT the old sitting will go back
plz plz i need help
thx to all
I’m not a professional in here
but I suggest for such cases post your configuration
or even best answer it is even better if you can draw a simple diagram of your network (specially when its complicated)
hope you get the answer, I had the same problem too and it was fixed after properly setting proxy server and firewall rules
MT support will ask that you upgrade to 2.9.5 and confirm it’s still a problem. If so, email support the required info and they will look into it.
Sam
