Plz Help Me
Have a local network consisting of 190 customer and I want to manage by Mikrotik router … Please note that I want to Distribution
Speed of the internet to clinets, as well as prevention programs spare the Internet … I want to know any Router appropriate for me to play this purpose
Use a PC with mikrotik installed.
thnk but i want hardware to manage this problem not software
it depends on how much bandwidth each client will have, how many firewall rules and other factors.
they will have a 20 kps and about firewall i cant understand what does you mean ((you mean filters)
note … my network (wired not wireless ) :frowning:
What do you mean by 20kps? Is it 20000 packets per second or 20kilobits per second? :slight_smile:
Most likely 433 or 433AH will be good enough. Anyway, look at this speed comparison diagram
http://www.routerboard.com/pdf/tests_april_2009.pdf
Have a look at www.routeboard. com for comparesons. If users using 29k than i would sugest using RB450G. I replase a PC with around 50 users with this and running good.
