plz help pllllllllllllllllllllllllllllllz
how can i activate the cache in mikrotik version 2.9.27
please and thanks for all
what cache do you mean?
you have to change ur web-proxy setting and change the value with port 8080 and then Enable ur cache .
thank u very much for answer
and i want to ask u if u can help me in this prob. :blush:
yahoo messenger did not work in “no proxies” it just work in "firewall with no proxies"in this option the webcam and voice did not work ,if u can tell me how can i fix this problem in MT and thank u again for all.
Dose this problim happend after or before WEB PROXY setting ?
explain in detail plz .
after WEB PROXY setting and i use port 5500 & 5050 but its no result.
tell me if u have any idea about this problem .
thanx
You dont have to use this port which it related yahoo!
set the folowing in web-proxy
enabled: yes
src-address: 0.0.0.0
port: 3128 OR 8080
hostname: “proxy”
transparent-proxy: yes
parent-proxy: 0.0.0.0:0
cache-administrator: “webmaster”
max-object-size: 50000KiB
max-cache-size: unlimited
max-ram-cache-size: unlimited
Hello Ram.
Did you close your proxy, i guess thatwas what you did; you only allow ur LAN subnet and deny others.
For you to make yahoo webcam to work, you have to allow TCP/5100 in your firewall and in ur webproxy access list.
Please export you config in /ip web-proxy
test this and give me a reply.
ram please upgrade to latest RouterOS 2.9.42
