plz plz help we are done
hi
we are using mikrotik routerboard 433 to provide wireless broadband services but sometimes ping is very high eventhough signal strenth and ccq are good can somebody help us in configuring our devices so that we get max performane
our current config is
waiting for replies eagerly
set only-G standart and unsheck all rates from B standart rates , use only G standart
i have done like that but still problem persists ?
Have you tried the adaptive noise immunity? Also I would suggest just using the default setting for the rate selection.
You might look at your registration tables. For instance if all your radios are linking up around 54MB/54MB and you have a few linking up at 2MB/1MB; once the really bad connections start pumping much data it will hose everyone on the tower. Usually you’ll start to see extremely high pings and PPPoE sessions will begin to time out.
Eric
Any particular reason you’ve chosen not to use Nstreme if all the boards are running RouterOS?
Have you tried manually setting ACK timeout to furthest away client + margin,
I note you have dynamic 30us on AP, what are the ACK timeouts reading from clients,
Can you attach examples of low/high pings?
Also data rates should be set to default on the AP, adjust CPE data rates to get best CCQ for each unit.
I have the same problem… similar situation., 2 computers on 2 meters , pings are 230 - 400 to mikrotik… signal strength excellent… if creator of this topic fix his ping on customers, ill check for answer here how to fix that problem :smiley:
hmm… I resolve my problem with simply reastart computer later :smiley:
