Plz security 128bit wep
:sunglasses: Hi…i need configure the AP with 128 Bit WEP security…but I only view 104bit and 40bit…plz help if someone know…how to do…
Best Regard… :slight_smile:
104 is the same as 128, different vendors use different description.
Use 128 encryption, it should work fine.
http://en.wikipedia.org/wiki/Wired_Equivalent_Privacy
Thank you… :smiley: for you help…but i’ve doubt respect about the hexadecimal and decimal password…In this case i need a hexadecimal password to my AP.
I selected a 104 bits WEP but my password must be a hexadecimal password. how to write a hexadecimal password? I’m confused because i view 0X before the textbox.
Sorry for my bad english :laughing:
Best regard.
0x{insert password here}
example:
[40bit]
0x0102030405
[104bit]
0x0102030405060708090a0b0c0d
Entered on a client system would be in the format the local operating system or wireless software supports.
Thank very much for you help!!! :smiley:
Best regard.
