PoE-Cut-Off randomly
Hi guys,
i have a PowerBox Pro mounted outside on the tower. The PowerBox Pro is powered via ETHER-1 POE-IN.
There is a Rocket-M5 connected on ether-4 and a PowerBeam M5 connected on ether-5.
Both devices will be powered via the PowerBox Pro.
The both APs are rebooting randomly at the same time. PoE-Priority is 10 for M5 and 1 for PBE. So if there is a issue with the power-feed M5 should be disconnected first. But in my case both devices are rebooting at the same time.
There is no information in the logs. If ROS will power-cycle a port, or will disable poe on a particular port, this will be logged, right?
What can cause this isse if there is no information in the logs?
Hi, I’m having the same issue, did you manage to solve it please?.
Have you looked at the power consumption of the Rocket-M5?
Maybe the power box cannot handle this.
Is it possible to power the powerbox with the power jack?
Maybe this solves your problem.
