PoE-in ePoE-out
Hi, i can not understand the difference between PoE-in ePoE-out.
I would like to buy CRS125-24G that only has PoE-in, can it give power to a RouterBOARD mAP lite?
thank you
Poe-in that the device itself can be powered by poe, poe-out it can power other devices attached to that port.
From the picture it says port1 is poe-in but nothing is shown about this in the quick guide powering section, neither in the brochure.
You will be needing one of these (10/100): https://routerboard.com/RBPOE
ok But the Lan 100Mbit cable is standard?
On the mAP lite it is.
