POE-IN supported by Cisco POE switch
Just a quick question. Will Routerboard that support 802.3af/at standard powered by cisco poe switch that support such standard?
I’m not quite sure what you are asking but if it states that a routerboard supports 802.3af/at then it will support that and work with any (most) POE switches that also adhere to that standard. As an example, I use a lot of wAP AC’s and those work fine with multiple brands of switches I’ve tried them on.
Thanks you very much for your info. I just dont see tested cisco poe switch in mikrotik poe-in chart. Will cisco poe switch work well with routerboard that support 802.3af/at?
