POE issue port 2 v1.15
The issue i was hoping was fixed in the new version was unfortunately not the port poe is set to on and the status was disabled. this only every happens on port 2 and is the first time encountering this on 1.15 the uptime on the RB260GSp is 1 day 9 hours at the time of problem. I will attach screenshots for the problem and me disabling the poe and re-enabling the poe and having the access point power back on.
Problem
Turned POE out off
Turned POE out on
Seems to happen once every two to three days now.
For me update to 1.15 resolve that problem.
Do you try to calibrate maybe help ?
Yea we always calibrate the poe ports during deployment. Doesn’t really seem to make a difference.
