You changed the settings on the both sides?
If you want to properly test the wireless connection/bridge, put a computer running openspeedtest server at one end and another computer at the other end and test it!
done!
but the situation does not change, speedtest to 239mbpsYou changed the settings on the both sides?
I’m sorry, how should I do all this?
done!
i lunched speedtest from terminal from transimetter:
/tool bandwidth-test 23.162.144.123 user=North-Idaho-Btest-Server pas
sword=I-Am-Not-A-Cron-Script direction=both
status: running
duration: 53s
tx-current: 388.6kbps
tx-10-second-average: 319.1kbps
tx-total-average: 501.6kbps
rx-current: 213.7Mbps
rx-10-second-average: 209.0Mbps
rx-total-average: 204.4Mbps
lost-packets: 2119
random-data: no
direction: both
tx-size: 1500
rx-size: 1500
connection-count: 20
local-cpu-load: 29%
remote-cpu-load: 10%
Don’t test ON the devices themselves.
They are not really suited CPU wise to handle that load. Your results will be too low because the local CPU most likely will not follow.
You are also testing via your ISP. You don’t know what the impact is there.
Use 2 PCs within your network, one on each side of that link, both having iperf3 application and test between those 2 PCs, crossing the devices to be tested.
Then you also are sure you’re only testing your network on its own, not your ISP (that can be looked at later).
Side notes:
Why is hardware offload disabled on ether1 of the “transmitter”?
add bridge=bridge1 interface=wlan2
add bridge=bridge1 hw=no interface=ether1
add bridge=bridge1 interface=wlan1
Try setting it hw=yes.
You have a DHCP server attempting to run on a slave interface (same ether1)
/ip dhcp-client
# DHCP client can not run on slave interface!
add disabled=no interface=ether1
add disabled=no interface=bridge1
Disable or remove it.
You are also testing via your ISP. You don’t know what the impact is there.Use 2 PCs within your network, one on each side of that link, both having iperf3 application and test between those 2 PCs, crossing the devices to be tested.
I should understand how iperf3 works
Side notes:
/interface bridge port add bridge=bridge1 interface=wlan2 add bridge=bridge1 hw=no interface=ether1 add bridge=bridge1 interface=wlan1Try setting it hw=yes.
/ip dhcp-client # DHCP client can not run on slave interface! add disabled=no interface=ether1 add disabled=no interface=bridge1Disable or remove it.
Disable both?
You have a DHCP client on ether1 that cannot work because ether1 is part of (slave to) the bridge.
Ros is trying to tell you that.
The one on bridge is running, you should know whether you have need for the devices to use it or not.
Very likely not, as the two devices should form a sort of “wireless wire” bridge and all the connections should happen at L2 level, it is (should be) like the two devices are a single switch (transparent) for the network, the devices need not an IP address if you access/configure them via Winbox using their MAC, while they may need one for access via browswe/webfig.
The “other side” (receiver) has also a DHCP client on bridge.
Hi, I’m back, sorry for my absence.
So I tried, as someone suggested, to test the connection between the two ptps with IPERF. And this is the result.
Connecting to host 192.168.1.100, port 5201
[ 5] local 192.168.1.180 port 56340 connected to 192.168.1.100 port 5201
[ ID] Interval Transfer Bitrate
[ 5] 0.00-1.00 sec 5.25 MBytes 44.0 Mbits/sec
[ 5] 1.00-2.00 sec 5.38 MBytes 45.0 Mbits/sec
[ 5] 2.00-3.01 sec 5.75 MBytes 48.0 Mbits/sec
[ 5] 3.01-4.00 sec 5.00 MBytes 42.2 Mbits/sec
[ 5] 4.00-5.01 sec 4.50 MBytes 37.6 Mbits/sec
[ 5] 5.01-6.00 sec 5.00 MBytes 42.1 Mbits/sec
[ 5] 6.00-7.01 sec 4.62 MBytes 38.7 Mbits/sec
[ 5] 7.01-8.01 sec 5.38 MBytes 45.0 Mbits/sec
[ 5] 8.01-9.01 sec 4.88 MBytes 40.7 Mbits/sec
[ 5] 9.01-10.01 sec 4.12 MBytes 34.8 Mbits/sec
[ 5] 0.00-10.01 sec 49.9 MBytes 41.8 Mbits/sec sender
[ 5] 0.00-10.02 sec 49.9 MBytes 41.7 Mbits/sec receiver
iperf Done.
ip .100 is pc where is connected the receiver
ip .180 is pc where is connecet the transimitter
I also disabled DHCP on ether1 as suggested.
There exist a lot of PoE injectors that are 100mbit capable
You need the Gigabit model https://mikrotik.com/product/RBGPOE
please double check you have Gigabit written on them
You need the Gigabit model https://mikrotik.com/product/RBGPOEplease double check you have Gigabit written on them
Thanks for your response,
However i have gigabite PoE injector
