Hi in here.
I have a Little Q. I will make a little setup with 1 750UP and 3 STX SA5 running on POE.
My Q here is now: On the 750UP there is a power connecter, but I need to have the 750up in top of the 30 m antenna, that is a long way, so what is the deferent between power connecter and port 1 POE IN if I use poe adapter?
Hmm and the cable have to Be 50 m so that Will not Work i thing my setback is back to normal mode with poe on singel cable to stx so mucth for the new 750 in box
