poe out on poert 4 omnitik
I have purchased a omnitik upa-5hnd
ver 6.7 os
configured port 4 poe forced on
verfied that it is set in config
led 3 lights red.
plug in sxt 5hpnd into port 4 sxt does not power on.
can some one give me a direction to go in to make this work.
I have also tried leaving it to auto too.
also when I do a export it does not show my config changes so I can do this on mult omnitiks
thanks
strange that 3 is red, and not 4 , reset configuration is maybe a solution for your problem …
well i allways solder the omnitiks inside for poe out …
The red light order is incorrect on OmniTik.
