Isn’t the poe-out supposed to work on the 750GL?
I have it all running fine. I have it set to switch all ports with a master port of ether 1.
It just never powers the 433AH plugged into ether2
[admin@1] /interface ethernet> print
Flags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 R ether1 1500 D4:CA:6D:C3:F9:05 enabled none switch1
1 S ether2 1500 D4:CA:6D:C3:F9:06 enabled ether1 switch1
2 S ether3 1500 D4:CA:6D:C3:F9:07 enabled ether1 switch1
3 S ether4 1500 D4:CA:6D:C3:F9:08 enabled ether1 switch1
4 S ether5 1500 D4:CA:6D:C3:F9:09 enabled ether1 switch1
[admin@1] /interface ethernet> set 1 poe-out=forced-on
