Can a Microtik RB960PGS-PB being powered by 48V be configured to supply both 24V PoE (Max 7w) on a single port, and 48V 802.3af PoE (max 9w) on a different port?
I’d like to be able power a UBNT Litebeam AC and a UBNT Mesh AP Pro at the same time. Can that be configured on through the GUI ?
i dont think so
references
from product data-sheet:
Ethernet ports 2-5 can power other
PoE capable devices with the same voltage as applied to the unit
from product quick guide
Power output
Device supports passive or standard 802.3at/af PoE input/output. Ethernet ports 2-5 can power other
PoE capable devices with the same voltage as applied to the unit.
it is clear that this routerboard only bypass the supplied voltage to POE out ports
i think this device suits better for your needs but you must find an outdoor enclosure for it
https://mikrotik.com/product/crs112_8p_4s_in
brochure
https://i.mt.lv/routerboard/files/CRS112-8P-4S-180201082431.pdf
from quick guide
https://i.mt.lv/routerboard/files/1529742363CRS112-8P-wg.pdf
Powering
The device has two direct-input power jacks (5.5 mm outside and 2 mm inside, female, pin positive plug).
One DC input supports 48-57 V DC, the other supports 18-28 V DC. > Only a 28 V PSU is included> . You can use > either one> ,
or > both inputs at the same time> . This will also affect the PoE output functionality (see below section).
The power consumption of this device itself under maximum load is up to 12 W.
PoE output
This device can supply PoE powering to external devices from its ethernet ports. The output voltage will be
selected automatically, depending on what kind of adapter is connected, and what kind of voltage the connected
device requires. The device can power 802.3af/at devices, but a > 48 V PSU must be acquired separately> .
maybe 2 powerbox one for 24 and other for 48volts is other option
another option is finding an poe converter to adapt the different voltage device, this option can fit for your needs and be cheaper
Like this: https://mikrotik.com/product/rbgpoe_con_hp
Sent from my iPhone using Tapatalk
