Hi there,
I have a hEX PoE (RB960PGS) and I want to use the PoE-OUT on several ports.
The device is brandnew and comes with factory software 6.40.
When I use the DC IN Jack with 24V / 2,5A power supply and plug in a LAN cable to eth1 and connect from winbox I have an poe-out error message “short circuit” on eth4 (no cable plugged in).
that massages comes up and disappears 1 time per second.
I then changed the DC in from 24V / 2,5A to 48V / 1,46A. When I use this power supply the message “short circuit” is shown permanently.
I tried to use newest software version 6.44rc4 but that didnt help.
I tried to change PoE out settings on port eth4 from “auto on” to “forced on” and plugged in eth1 of an hAP ac (RB962UiGS-5HacT2HnT), but then I get an “overload” error.
When I disable PoE out feature on eht4 and try to use eth5 instead with “auto on” the hAP ac doesnt work. When I change on eth5 to “forced on” then I get “overload” error, too.
The tech spec of (RB960PGS) says that there are 450mA per port output, when DC in is > 30V (it is 48V). So 48V x 450mA = 21,6 Watts.
MAX powerconsumption of hAP ac is 17Watts. So why is there an overload?
Is there a damage on the new routerboard or how can I solve the problem?
Regards,
horstkevin
