PoE question / devices connected in series
Would such PoE configuration work?
\----- 220V ----- RB260GSP --\
                              \------ PoE -----> RB260GSP --\
                                                             \------ PoE -----> RB951Ui-2HnD
yes, surely
…except that the 260 in the middle, including its clients, shall not draw more power than it is allowed for a single PoE output port (1 amp if I remember correctly) :slight_smile:
500mA, to be precise.
So… will this current be sufficient to power both RB260GSP and RB951Ui-2HnD?
500mA???
MAX 1A x PORT!!!
http://i.mt.lv/routerboard/files/RB260GS-140417124849.pdf
The RB260GSP want 250mA
The RB951Ui-2HnD want 300mA
And if you not put on PoE out more device than writed before, is 550mA and all is working.
The RB951Ui-2HnD do not power more device, right? (The RB951Ui-2HnD support only 500mA max on PoE out!!!)
