POE Split
Hi
I have an RB 433 using 18v poe 2 cards no problems works fantastic
What I want to do is use one of the spare ethernet ports and cable it to around 15 metres away to an RB 711 using the same or upgraded power supply. this is needed to get round dense foliage/shrubs which is blocking signal.
How can I get power to the additional rb711
poe 18v > (12m)Rb433 2 cards > 2nd ether port > rb 711 (15m)
thanks
Use this:
http://www.wlanparts.com/product/TP-POE-YSPLT/Passive-POE-Y-Splitter.html
and one of these:
http://www.wlanparts.com/product/EBU-101-01/Power-Over-Ethernet-Injector-EBU-101-01.html
If you need more power you can use something like this:
http://www.wlanparts.com/product/POE-HP-24I/POE-High-Power-Power-Supply-Inserter-24VDC-at-2A-50W.html
Does that work?
thanks for reply
looks like it will work. thinking of using an injector extractor pack, although info is short. should work subject to any voltage drop rectification.
