I have found an issue while I was working with Mikrotik versions.
I need to use an active POE switch with 24 ports at the same time I need upgrade my routerboard RB1100 with the version 6.12 or similar. I usually work with Cisco or D-Link switches. I can scan this devices and make the binding with the RouterBoar while I have the version 6.0 or lower but at the moment I use a higher version I can not scan this devices. All this happens while I have a hotspot active. However, If I do not use hotspot I can scan the devices using upper versions without any problem.
I need solve this issue as soon as possible.
Has anyone the same issue?
Thanks!
