Hi all,
i’m trying use this swtich managment poe for power on 4 netmetal5.
But all always poweroff.
Someone have you experience with this swtich?
Hi all,
You need passive poe ..
This switch is poe port 802.3at and 802.3af
NetMetals only support passive PoE, they do NOT support .3at/.3af.
Check here:
http://routerboard.com/RB921UAGS-5SHPacT-NM
802.3af support no
ok,
it’s possible force activation poe?
You can use this convertor → 802.11af/at to pasive poe:
http://routerboard.com/RBGPOE-CON-HP
if you read wikipedia you can understand poe 802.2at is 48 volts
if you read mikrotik manual or quick start guide you can understand that mikrotik uses 8-30 volt
resolve with this.
http://www.panoptictechnology.com/network-smart-adapters-mikrotik/ ?
