Is there a wifi range difference between PoE power supply vs from the power outlet socket for example on hAP ac lite?
Is there a wifi range difference on PoE power supply on hAP ac vs hAP ac lite?
As long as your POE is providing the max power draw for each device, then there should be no difference between POE and Power Supply.
