point to multipoint internet distribution challenge
Greetings to all
As i am new to the forum I am not sure if this topic has already been delt with. I am hoping that some of the gurus out there will be able to help me with my small challenge.
I have a main tower supplying 5ghz to centralised tower. The central tower consists of a 5ghz & 2.4ghz radio. An omni on the 5ghz allows for the signal to be sent to the 4 remote towers. All towers also equipped with 2.4ghz radios to supply wireless around park.
main tower and all surrounding towers are working perfectly on the 2.4ghz range but the centralised one (although fitted with a 2.4ghz card) allows users to connect but has a issue with surfing (very slow and sometimes non existant).I have compared settings with the other working towers but still I cannot seem to solve this one.
A replacement routerboard (112) with cards has been used but problem still persists.
Can someone please help me with this issue
Post your configuration.
Greetings and thanx for such a prompt response.
With regards to the configuration you request, can you give me more of an indication as to what you require?
Regards
Hope this info helps
0 name=“Suite 59 BB” mtu=1500 mac-address=00:80:48:41:28:CE arp=proxy-arp
disable-running-check=no interface-type=Atheros AR5413
radio-name=“BB Suite 63” mode=ap-bridge ssid=“BB” area=“”
frequency-mode=manual-txpower country=no_country_set antenna-gain=0
frequency=5200 band=5ghz scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms preamble-mode=both compression=no
allow-sharedkey=no
1 name=“Hotspot” mtu=1500 mac-address=00:80:48:41:46:F4 arp=enabled
– [Q quit|D dump|down]
