I have one general question.
Let’s say I have a network with one central AP and multiple home users that connect to that central point with CPE equipment. Each user is a separate entity.
There is about 20 users connected to central AP.
There is one more router “behind” the central AP.
What is the best way to setup a network ?
- do you use Layer 3 on central AP - and give each user a separate IP adress/subnet?
- do you use VLANs?
What would be the best way to set it up regarding the resource consumption on central AP, complexity of configuration etc…
