Point to Multipoint
ok, I’ve played with both wireless options for Link Aggregation, WDS+Bonding and Nstreme Dual. Honestly I think I would prefer the WDS+Bonding, specifically because of the fault tolerance. Here is chart of how it’s setup and working now…
My big question is can I take this a step further and make it a Point to Multipoint aggregated connection? Like the following:
I only have two Mikrotik RB433/AH and I need to make sure this will work before I buy a 3rd.
Thanks,
Jairus Knudsen
anyone wanna take a stab at this?
Hi
well is possible do that but plz say me.
what kind of antenna will you use?
kind of traffic "data, video & voip?
the traffic that you pass throught the link is constant?
I have some links point to multi points with 532 working, but if you can post more information for help you.
best regard.
