Point to Multipoint
Having an issue with a multipoint setup and hoping that someone can assist.
Currenty have 2 remote sites setup and 1 is having signal issues due to trees (between -72 to -76) and the second site has very good signal strength. The issue is that the port on the router that connects the AP is showing a large number of Buffer Underruns and both sites are experiencing VOIP and data issues. Is the AP spending extra cycles trying to service the radio that is having connection quality issues?
Thnanks..
Depends on your setup, but make use NV2 as protocol. Will sort the problem if it is the case.
I am running RouterOS version 3.30 on the device. I am assuiming that NV2 is not supported in this version. Which version would I need to have this option?
Thanks… :slight_smile:
Not sure. Thinking OS 4.
Nv2 was introduced in v5, and was backported to v4.17 (only!)
