Point to Point bad CCQ
I’ve a point-to-point mikrotik wireless link using two groove with externel ant.
the link is quite good, the signal level are this:
-65 tx
-78 rx
CCQ 6/70 % (tx/rx)
signal to noise: 57db
but thw TX CCQ has no bandwith…
Can you help me what is wrong ?
-78 is not what I would call good
try to align your link
Use stronger antennas or align them better.
I’ve two 29 dbi dishes on both sides, I think there is something wrong with N configuration or HT MCS config…
Ok, I solved the problem… we adjust some features in MCS and now we have 99/98 CCQ with 102/94 mb
Nothing about aling and all that stuff…
Can I ask which features did you adjust which solved this issue?
+1
Intrigued ???
I have 1 km, good signal, los and 6% ccq. What have you done?
