Point to point bridge, whats wrong here?
Hi im new to Mikrotik and that might be my only problem. Well anyway, i got 2 532boards with long range radios which i was planning to set up as an backbone link, only at transparent bridge. WDS is working fine, but when enabling Nstreme the link drops.
Here is my configs
Base/bridge config:
[admin@MikroTik] interface wireless> print
0 R name="wlan1" mtu=1500 mac-address=00:15:6D:10:02:BB arp=enabled
disable-running-check=no interface-type=Atheros AR5213
radio-name="00156D1002BB" mode=bridge ssid="nstreme" area=""
frequency-mode=regulatory-domain country=no_country_set antenna-gain=0
frequency=5805 band=5ghz scan-list=default rate-set=default
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-a/g=6Mbps max-station-count=1 ack-timeout=dynamic
tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default burst-time=disabled dfs-mode=none
antenna-mode=ant-a wds-mode=dynamic wds-default-bridge=bridge-interface
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=no
[admin@MikroTik] interface wireless nstreme> print
0 name="wlan1" enable-nstreme=yes enable-polling=yes framer-policy=exact-size
framer-limit=3200
Stations config:
0 R name="wlan1" mtu=1500 mac-address=00:15:6D:10:02:C6 arp=enabled
radio-name="00156D1002C6" mode=station ssid="nstreme" area=""
54Mbps
compression=no
0 name="wlan1" enable-nstreme=yes enable-polling=no framer-policy=exact-size
framer-limit=3200
Ive tried the cut and past from mikrotik examples, but still no bridging. Seemes like the base and client can se each other but not communicate. And if i just diasble Nstreme and add a WDS interface its up running at once. all active interface is part of same bridgegroupe on each site.
If you can se any obviouse error i have made here i would be happy if you could share it with me.
have you checked this one: http://www.mikrotik.com/docs/ros/2.9/interface/wireless.content#4.13.21.2
[quote="totalnett"]Hi im new to Mikrotik and that might be my only problem. Well anyway, i got 2 532boards with long range radios which i was planning to set up as an backbone link, only at transparent bridge. WDS is working fine, but when enabling Nstreme the link drops.
Here is my configs
Base/bridge config:
framer-limit=3200
Stations config:
framer-limit=3200
Highlighted values are not the same, and must be.
WRONG. It doesn’t matter what settings you have in the nstreme clients configuration. The only argument that does matter for the nstreme client is ‘enable-nstreme’.
I dunno know, my link seemed to drop if they were not set the same. Must have been a fluke.
My apologize the the forum for misinformation.
:standing in the corner:
