Point to Point Wireless Bridge
Hi all,
I am having trouble with some configuration of one of my wireless cards (AR5213) trying to set up a point to point network (Mikrotik wlan1 to AP in point to point mode) for a backhaul circuit.
Here is my delemma, most AP’s im familiar with including the ones we use for our CPE require a mac address to complete either “point to point” or “point to multipoint” (ill refer to as PTP and PTMP from here)
I have tried many combinations with the wlan1 in bridge mode but how do i get it to associate with the CPE in PTP mode by the CPE’s mac address.
So its like this CPE is PTP mode with the mac of the wlan1(mikrotik) card as its peer like this
Any tips or pointer would be great
Geoff
hello all,
you can try with connect to MT i thing better, if use AP to AP with WDS
that's methode same freq, ssid, band and make WDS on MT AP
Peace all
Balimore DOT com
try setting the Mode: to Station
If your WAP-0006 Atheros based AP, then you cant connect to mikrotik by WDS, i try it many times by D-Link 2100, 3200, 7100... I think its ditherens in WDS protocol, i write this to mikrotik, but they don`t know how to do this…
Thanks to all who helped here.
