point to point
I want connect between two (routerboard 433) without use bridge between ether and wlan
What do you mean exactly? Do you Want to connect two RBs and have different Networks?
If don’t need bridge, set different network IP addresses to ether and wlan and then router route between them.
Hi
No, I connect with same network , but when connect with SSID I make Bridge with (Wlan and ether1) in RB433.
can I connect with SSID but without make Bridge between Wlan & ether.Because of when I use this way Always return IP from other networks and this IP affect on my network .
So, you mean you suffer with broadcast?
Can you tell me more about your network? diagram, IPs and devices and also your purpose of connecting to that network.
