Pointing dishes
Hi!!!
I’m new using mikrotik devices.
I got a pair of RB433/dishes, when I configure them inside office everything went well, obviously pointing dishes with 30ft of separation its easy, and I now the configuration was fine.
The problem is pointing RB/dish A on the main office to RB/dish B on the branch office located at almost 2.2 miles, so I cant see anything, i’m just calculating the direction, but I wonder if mikrotik has some kind of tool to assist on pointing/aligment step. Mostly what I need is how to find the point B because I cannot even see it because it is so far.
If not, please share with me what method do you use to get the dishes point perfectly one to another.
thx a lot!!!
Do you have clear line of sight between locations?
I wish to be sure of it, The most I get is I can ping from one point to another, but when I try to transfer files it is slow and pings start to get lost. So probably I have nothing between blocking.
Have you done the calculations to check for fresnel? You have some some that additionally will tell you the azimut so that you can use a compass (your smartphone surely has one) to aid in pointing.
Which Parabolic dishes are you using?
