Is the SXT G-2HnD working good with one polarisation (horizontal OR vertical)?
I would like to connect as CPE to vertical base-station antenna. What chain I should select for that config?
just leave them both on, the sxt will work it out all by itself
Have Yot tried it yourself? I have tried. Theoretical it should be, but…
when I’m connecting it (SXTG-2HnD) do vertical base station antenna, the signal is much better when I turn it (SXT) at 90degrees.
ch0 is H and ch1 is V for SXT 5hnd, maybe is the same for 2hnd. Ch0 can’t be disabed, haven’t tried because I use all with dual chain.
I use all my sxt that connect to single chain v pol AP’s with both chains enabled (all four boxes ticked) and they work just fine.
