Pole mount for WAP 60G AP
Hi everyone,
I would like to mount a WAP 60G AP on a pole.
Which pole mount (Quickmount Pro or Quickmount pro LGH or other) is the right one for the WAP 60G?
Many greetings
Rene
Hello
Is there an actual need for QMP or QMP-LHG? wAP 60G are sold together with (included parts) metal ring (one) and plastic zip tie, which you can use for pole.
https://mikrotik.com/product/wap_60g#fndtn-specifications
But, with above mentioned parts you will be able to rotate device only around pole (without an option turn it up or down).
If there is an actual need for rotation up or down, then you can use QMP like shown in photo: https://i.mt.lv/cdn/rb_images/1445_hi_res.png
There may be a requirement to adjust the APs up and down if the heights of the APs on the buildings are different. Since the range for the APs is relatively short (30-50m), a necessary height correction is required. Thanks for your tip.
Many greetings
Rene
