Policy based routing and vpn
I want to route a specific traffic through a vpn, prefrebably sstp (MS-sstp configuration from vpn gate). I was successfully able to connect to the vpn server, but my traffic not routing through the vpn. I followed this https://wiki.mikrotik.com/wiki/Policy_Base_Routing . Any help will be highly appreciated.
Without configuration export, we can only guess why it is not working. Post exported configuration and provide us the information about from which source IP address communication does not work?
dec/11/2019 15:53:51 by RouterOS 6.45.7
software id = BM4W-X3GK
model = RouterBOARD 962UiGS-5HacT2HnT
serial number = xxxxxxxxx
add admin-mac=xx:xx:xx:xx:xx:xx auto-mac=no comment=defconf name=bridge
set [ find default-name=ether3 ] advertise=
100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=sfp1 ] disabled=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1
password=xxxxx user=xxxxx
/interface l2tp-client
add allow=chap,mschap2 connect-to=101.99.74.214 disabled=no ipsec-secret=123
name=l2tp-out password=321 use-ipsec=yes user=456
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX
disabled=no distance=indoors frequency=auto installation=indoor mode=
ap-bridge ssid=xxx wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=
20/40/80mhz-XXXX disabled=no frequency=5765 installation=outdoor mode=
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods=“”
mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=
xxxxxxx wpa2-pre-shared-key=xxxxxxx
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
set discover-interface-list=none
/ip settings
set rp-filter=loose
/interface detect-internet
set detect-interface-list=all
add address=192.168.88.x/24 comment=defconf interface=bridge network=
192.168.88.0
/ip cloud
set update-time=no
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
/ip dhcp-server lease
add address=192.168.xx.xx client-id=xx:xx:xx:xx:xx:xx:xx mac-address=
xx:xx:xx:xx:xx:xx server=defconf
xx:x:xx:xx:xx:x:x:x:x:xx:xx:xx:xx:xx:xx:xx:xx:xx:x mac-address=
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=192.168.88.1 name=router.lan
/ip firewall address-list
add address=192.168.88.2-192.168.88.254 list=allowed_to_router
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment=“6to4 relay Anycast [RFC 3068]” list=
not_in_internet
add action=accept chain=input comment=“defconf: accept established,related”
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input comment=“Allow ADMIN to Router”
in-interface-list=LAN src-address-list=allowed_to_router
add action=accept chain=input in-interface-list=LAN port=xx protocol=tcp
add action=accept chain=input in-interface-list=LAN port=xx protocol=udp
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
add action=accept chain=forward comment=“defconf: accept established,related”
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
add action=accept chain=forward comment=" Allow Port Forwarding - DSTNAT"
connection-nat-state=dstnat connection-state=new in-interface-list=WAN
add action=drop chain=forward comment=“Block iMac1” disabled=yes
src-mac-address=xx:xx:xx:xx:xx:xx time=
15h30m-19h,sun,mon,tue,wed,thu,fri,sat
add action=drop chain=forward comment=“Block iMac 2” disabled=yes
add action=drop chain=forward comment=“Block iPhone” disabled=yes
add action=drop chain=forward comment=“Block HTC” disabled=yes
add action=drop chain=forward comment=“Block TV 1” disabled=yes
add action=drop chain=forward comment=“Block TV 2” disabled=yes
add action=accept chain=forward comment=“ENABLE LAN to WAN” in-interface=
bridge out-interface-list=WAN
add action=drop chain=forward comment=“Drop All Else”
add action=drop chain=forward dst-port=xx in-interface-list=WAN protocol=tcp
add action=drop chain=forward dst-port=xx in-interface-list=WAN protocol=udp
/ip firewall mangle
add action=add-dst-to-address-list address-list=YouTube address-list-timeout=
none-dynamic chain=prerouting comment=YouTube content=youtube.com
10m chain=prerouting comment=YouTube-googlevideo.com content=
googlevideo.com
add action=add-dst-to-address-list address-list=Netflix address-list-timeout=
none-dynamic chain=prerouting comment=Netflix content=netflix.com
add action=mark-routing chain=prerouting content=reddit.com new-routing-mark=
vpn passthrough=yes src-address=192.168.88.0/24
add action=masquerade chain=srcnat comment=“defconf: masquerade”
add action=dst-nat chain=dstnat comment=“Plex Media Server” dst-address=
0.0.0.0 dst-port=xxxx in-interface-list=WAN protocol=tcp to-addresses=
192.168.88.xxx to-ports=xxxx
add action=dst-nat chain=dstnat comment=“Resilio Sync (UDP)” dst-address=
0.0.0.0 dst-port=xxxx in-interface-list=WAN protocol=udp to-ports=xxxx
add action=masquerade chain=srcnat out-interface=l2tp-out src-address=
192.168.88.0/24
add distance=1 gateway=l2tp-out routing-mark=vpn
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh port=xxxx
set www-ssl address=192.168.88.0/24
set api disabled=yes
set winbox address=192.168.88.0/24
set api-ssl disabled=yes
/ip ssh
set forwarding-enabled=remote strong-crypto=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/system clock
set time-zone-name=Asia
/system logging
add topics=wireless,debug
/system ntp client
set enabled=yes server-dns-names=
0.pool.ntp.org,1.pool.ntp.org,2.pool.ntp.org,3.pool.ntp.org
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
/Codebox]
Anyone wiling to help please?
As I see you are trying to match packets with content parameter:
  • content - Match packets that contain specified text
So, are you sure that every packet when you browse consists of string reddit.com? I don’t think so.
I would suggest you to configure it differently, for example, use tls-host matcher or firewall address-lists.
Can you please elaborate it a bit more?
These days we use encrypted connections (HTTPS://) and you are allowed to see where the traffic is heading by SNI and translates to using tls-host matching instead of using the content field.
add action=add-dst-to-address-list address-list=Netflix address-list-timeout=\
becomes
none-dynamic chain=prerouting comment=Netflix tls-host=netflix.com
Like this?
Mangle rule:
chain=preoruting action=add-dst-to-address-list protocol=tcp address-list=reddit
      address-list-timeout=none-dynamic log=no log-prefix="" tls-host=reddit.com
NAT rule:
chain=srcnat action=masquerade src-address=192.168.88.0/24 dst-address-list=reddit out-interface=l2tp
/code]
It is impossible to change the routing of TCP packets based on their content (like tls-host or l7 filter)!
This is because first TCP sets up the connection (SYN, SYN ACK, ACK) and then the first packets are sent which you then trap and you change the output interface.
But this will not affect the first packets! The connection will die because you suddenly have changed endpoint IP address.
Now, with the address list you may have a little more luck as the first connection attempt will add it to the address list and then the connection will die, but the second attempt to the same address will be immediately routed correctly.
I don’t know how well that will work out, it depends on how many addresses there are for the service and how often they change.
so, there is no working solution for that ?
When the “solution” based on adding the destination to an address list “sort of works” in that it will catch the 2nd and subsequent connection and route that correctly, but the first one is always going to be stuck. There is no way to solve that.
Of course when you know the exact domainnames of the destinations you want to route via vpn (not *.reddit.com but like www.reddit.com) you can add them to your address list before.
