Policy based routing issue with 2 gateways?
I have 2 dsl connections going into an RB450. I am using routing marks so that roughly half of the internal ips go out one gateway and the other half go out the other gateway. The issue I run into is that when I try to switch an ip or a subnet to go out the other gateway by changing the routing mark for those packets, that subnet or ip loses connectivity for awhile.
I found that if I put a static dns on a computer, then this does not happen.
Looking for advice to try and pinpoint what is going on.
what do you mean by ‘put a static dns’?
if you have established NATted connections via one gateway, if you change the gateway, NAT address is still the same, so you need to kill all those connections so that they were re-established. otherwise they will just timeout
On a windows pc you can select ‘obtain a dns server address automatically’ or you can select ‘use the following dns server address’. When I input the dns server address then I don’t have issues.
I understand that the established connections will timeout. Even new ones I try to make don’t work though either.
so, you put manually the same address as obtained automatically?..
Yes, just for the dns server.
any ideas?
Are the two ADSL lines from the same ISP?
My guess is that, when you change the DNS in a PC, you actually flush the
dns table of the PC, it will be the same as if you right-click on the network
connection icon and choose “repair”. So I think it is not a DNS issue, most likely
the Windows needs to reestablish connections.
The 2 ADSL lines are from the same ISP.
But I am not changing the DNS on the PC to static after I lose connectivity. It’s set to a static address prior to switching gateways and it doesn’t lose connectivity no matter how many times I switch gateways.
I am wondering if you are on the right track though. I might test with a cable connection I have access to, to see if that behaves differently.
I left the dns address to be assigned automatically and tried the “repair” option and it did not fix the connectivity issue so maybe this is not the issue?
Are the two pppoe-client configured with the same MTU and MRU?
I think they are, but just to be sure.
You can try to set a kind of “transparent dns cache” by adding the following to the router:
add chain=dstnat action=redirect to-ports=53 protocol=udp dst-port=53
you should also let Router to accept requests of DNS:
set allow-remote-requests=yes
MTU and MRU are the same.
I tried the redirect rule and I wasn’t successful.
I had the remote-requests set to yes already.
By the way, I really appreciate the suggestions. Thank you.
Have you tried to ping www.google.com from the PC at the moment when it has no internet
and then another ping when it is connected? This is to see if they are resolving diferently,
although there is not much chance since they are using the same ISP.
The DNS you are using is from ISP? if that is the case have you tried a public DNS?
One last thing, in the mangle it would be better if you mark connections first, and based on that
mark then mark the routing. But you should be carefull not to mark the traffic of the router itself.
It could be a chance that with mark-routing, probably you are redirecting IP of WAN2 to gateway
of WAN1.
This is my guess
When I try pinging www.google.com after I lose connectivity it says it can’t find host.
Yes I am using the dns from my provider. I thought about switching to a public dns but I didn’t know a good one that I could use and I worried that if I chose a public one, would it always be available, do they ever change?
I am not exactly sure what you mean about marking connections and then marking your routing. Could you explain that further?
If you want 192.168.1.0/24 to go through one gateway:
/ip firewall mangle
add chain=prerouting src-address=192.168.1.0/24 action=mark-conncetion new-connection-mark=subnet1
add chain=prerouting connection-mark=subnet1 action=mar-routing new-routing-mark=subnet1
add dst-address=0.0.0.0/0 gateway=(IP of WAN1) routing-mark=subnet1
The fact that you can’t ping www.google.com shows that it can not find the gateway to internet.
You should test by ping every step, or execute a tracert and see where it stops. I can not figure out
why it connects when you change the dns! As public dns you can choose those of google which are
8.8.8.8 and 8.8.4.4, or whatever you think is appropriate for you
I figured the reason it could not ping www.google.com is because it can’t resolve the ip address?
Yes, you are right
