Policy Based Routing through Mangle Routing Mark LAN to GRE
Hi
We are using Mikrotik Router Board M33G with ROS 6.46.3
We are using the LAN interface and LTE interfaces. We have created GRE tunnels over the LTE interface. These are all private SIM and NAT is not required.
We want to do per-packet load balancing or per-connection load balancing.
We are not able to do routing-mark to packets from LAN to GRE tunnel thus we are not able to achieve load balancing.
I have referred to many documents and forum documents but could not make it possible.
Is it possible to achieve the same in my network architecture? Can someone please help with a working configuration which i can try out.
I have tried so many configurations that I don’t have any template configuration to share here.
