Thank you for your help, but unfortunately it doesn’t work
The only thing I want is following:
webserver over ISP1.
All other pc’s over ISP2.
And if ISP2 fails than fallback to ISP1, only in this direction. If ISP1 fails than bad luck
And connection from all networks to and from webserver (restriction are done over firewall rules).
I have no idea how to achive that
Before I get my second ISP everything works fine, but that gives me headache since some time.
If it helps to find the problem, here my config:
nat:
0 ;;; QSC
chain=srcnat action=masquerade out-interface=pppoe-out1 log=no log-prefix=“”
1 ;;; Skytron
chain=srcnat action=masquerade out-interface=ether6 log=no log-prefix=“”
2 ;;; OVPN
chain=dstnat action=dst-nat to-addresses=10.10.15.2 to-ports=1194 protocol=udp
in-interface=pppoe-out1 dst-port=1194 log=yes log-prefix=“”
3 ;;; webserver
chain=dstnat action=dst-nat to-addresses=10.10.90.2 to-ports=443 protocol=tcp
in-interface=pppoe-out1 dst-port=443 log=yes log-prefix=“”
mangle
0 D chain=forward action=change-mss new-mss=1440 passthrough=yes tcp-fl
protocol=tcp out-interface=all-ppp tcp-mss=1441-65535 log=no
log-prefix=“”
1 D chain=forward action=change-mss new-mss=1440 passthrough=yes tcp-fl
protocol=tcp in-interface=all-ppp tcp-mss=1441-65535 log=no log-pre
2 ;;; webserver ueber QSC
chain=prerouting action=mark-routing new-routing-mark=to_QSC
passthrough=yes src-address=10.10.90.2 log=no log-prefix=“”
Filter Rules
0 ;;; allow already established or related connections
chain=input action=accept connection-state=established,related log=no log-prefix=“”
1 ;;; allow ICMP
chain=input action=accept protocol=icmp log=no log-prefix=“”
2 ;;; Drop everthing else expect from LAN
chain=input action=drop src-address=10.10.20.3 in-interface=!vlan20 log=no log-prefix=“”
3 ;;; allow already established or related connections
chain=forward action=accept connection-state=established,related log=no log-prefix=“”
4 ;;; Drop invalid connections
chain=forward action=drop connection-state=invalid log=no log-prefix=“”
5 ;;; allow connections from Managment Mikrotik Switch
chain=forward action=accept in-interface=vlan10 log=no log-prefix=“”
6 ;;; allow connections from Server
chain=forward action=accept in-interface=vlan15 log=no log-prefix=“”
7 ;;; allow connections from LAN
chain=forward action=accept in-interface=vlan20 log=no log-prefix=“”
8 ;;; Allow connection from DMZ (Vitocom)
chain=forward action=accept in-interface=vlan30 out-interface=pppoe-out1 log=no log-prefix=“”
9 ;;; Allow DNS from DMZ (Vitocom) to LAN
chain=forward action=accept protocol=udp dst-address=10.10.15.2 in-interface=vlan30 out-interface=vlan15 dst-port=53 log=yes log-prefix=“”
10 ;;; allow connections from Mobydick
chain=forward action=accept in-interface=vlan35 log=no log-prefix=“”
11 ;;; allow connections from BUS
chain=forward action=accept in-interface=vlan45 log=no log-prefix=“”
12 ;;; Allow connection for Guests
chain=forward action=accept in-interface=vlan60 out-interface=pppoe-out1 log=no log-prefix=“”
13 ;;; Allow DNS for Guests to LAN
chain=forward action=accept protocol=udp dst-address=10.10.15.2 in-interface=vlan60 out-interface=vlan15 dst-port=53 log=yes log-prefix=“”
14 ;;; Allow connection from DMZ (Webserver)
chain=forward action=accept in-interface=ether7 out-interface=pppoe-out1 log=no log-prefix=“”
15 ;;; Allow DNS und NTP from DMZ to LAN
chain=forward action=accept protocol=udp src-address=10.10.90.2 dst-address=10.10.15.2 in-interface=ether7 out-interface=vlan15 dst-port=53,123 log=yes log-prefix=“”
16 ;;; Allow LDAPs, MySQL from DMZ to LAN
chain=forward action=accept protocol=tcp src-address=10.10.90.2 dst-address=10.10.15.2 in-interface=ether7 out-interface=vlan15 dst-port=636,3306,389 log=yes log-prefix=“”
17 ;;; Allow PowerChute Network Shutdown
chain=forward action=accept protocol=udp src-address=10.10.90.2 dst-address=10.10.10.8 in-interface=ether7 out-interface=vlan10 dst-port=3052 log=yes log-prefix=“”
18 ;;; Allow Cifs to fs01
chain=forward action=accept protocol=tcp src-address=10.10.90.2 dst-address=10.10.15.3 in-interface=ether7 out-interface=vlan15 dst-port=139,445 log=yes log-prefix=“”
19 ;;; Allow input connection to Webserver
chain=forward action=accept protocol=tcp dst-address=10.10.90.2 out-interface=ether7 dst-port=443 log=no log-prefix=“”
20 ;;; OpenVPN
chain=forward action=accept protocol=udp dst-address=10.10.15.2 out-interface=vlan15 dst-port=1194 log=no log-prefix=“”
21 ;;; Deny ICMP Type 8
chain=forward action=reject reject-with=icmp-host-unreachable protocol=icmp in-interface=!vlan20 out-interface=vlan20 icmp-options=8:0-255 log=no log-prefix=“”
22 ;;; Deny ICMP Type 17
chain=forward action=reject reject-with=icmp-host-unreachable protocol=icmp in-interface=!vlan20 out-interface=vlan20 icmp-options=17:0-255 log=no log-prefix=“”
23 ;;; Deny ICMP Type 15
chain=forward action=reject reject-with=icmp-host-unreachable protocol=icmp in-interface=!vlan20 out-interface=vlan20 icmp-options=15:0-255 log=no log-prefix=“”
24 ;;; Deny ICMP Type 30
chain=forward action=reject reject-with=icmp-host-unreachable protocol=icmp in-interface=!vlan20 out-interface=vlan20 icmp-options=30:0-255 log=no log-prefix=“”
25 ;;; TCP port 0 DDoS protection
chain=forward action=drop protocol=tcp port=0 log=no log-prefix=“”
26 ;;; UDP port 0 DDoS protection
chain=forward action=drop protocol=udp port=0 log=no log-prefix=“”
27 ;;; Drop everthing else
chain=forward action=drop log=no log-prefix=“”
routes
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 192.168.0.1 1
1 A S 0.0.0.0/0 211.135.132.8 1
2 A S 0.0.0.0/0 192.168.0.1 1
3 S 0.0.0.0/0 211.135.132.8 2
4 A S 10.8.0.0/24 10.10.15.2 4
5 ADC 10.10.10.0/24 10.10.10.1 vlan10 0
6 ADC 10.10.15.0/24 10.10.15.1 vlan15 0
7 ADC 10.10.20.0/24 10.10.20.1 vlan20 0
8 ADC 10.10.30.0/24 10.10.30.1 vlan30 0
9 ADC 10.10.35.0/24 10.10.35.1 vlan35 0
10 ADC 10.10.45.0/24 10.10.45.1 vlan45 0
11 ADC 10.10.60.0/24 10.10.60.1 vlan60 0
12 ADC 10.10.90.0/24 10.10.90.1 ether7 0
13 ADC 192.168.0.0/24 192.168.0.103 ether6 0
14 ADC 211.135.132.8/32 91.212.12.51 pppoe-out1 0
route rules
Flags: X - disabled, I - inactive
0 dst-address=10.10.0.0/24 action=lookup-only-in-table table=main
