Hi guys. I have a little doubt… see this rules:
ip firewall mangle
chain=prerouting action=mark-connection new-connection-mark=coop_con passthrough=yes src-address-list=cooperativa
chain=prerouting action=mark-packet new-packet-mark=coop_pack passthrough=yes connection-mark=coop_con
chain=prerouting action=mark-routing new-routing-mark=cooperativa passthrough=no dst-address=!192.168.1.0/24 src-address-list=cooperativa packet-mark=coop_pack
ip route
dst-address=0.0.0.0/0 gateway=10.8.1.1 routing-mark=cooperativa
rule
action=lookup disabled=no routing-mark=cooperativa table=cooperativa
to these mark i routing somo clients to a second WAN. I was comparing this with the one used for PCC balancing, where precautions are taken so that packets enter and exit the same interface. Do you consider that this is enough? or appropriate to use the same form than pcc, obviating the flow divition part.
i waiting four your points of view’s!
best regards
