I would prefer to use this over load balancing. Load balancing seems to have a slight problem with programs like MSN, the connection intermittently drops. I assume this happems when the application switches destination IP’s and Mikrotik picks the other connection. Therefore I would prefer to stagger the clients between the two outgoing interfaces based on their source IP.
True, I only want it to go via 1 IP when it matters, say MSN by the sound of it, but when it does not matter use both IPs freely.
I’ve been intending to ask about this for a bit as the examples don’t seem to take such things into account. I am sure it can be done as u can buy boxes that can do this.
An example of where this is useful is segmented downloading with getright where you can get near the speed of both links for your download. However for applications that require you always to have the same IP (clara news) this does not work.
However I don’t want to just shove all usenet trafic down 1 link as this wastes the 2 link another user could be using for usenet.
