poll: u.fl vs. mmcx for sr2, sr5 and soldering
Thanks marksx for your info.
Un saludo
Kiket
Hello marksx,
Your work is fantastic. Can you please email me?
Cheers,
jon (dot) brewer (at) araneo (dot) net (dot) nz
m.burzynski (at) cyberbajt.pl
Where can one purchase that software, or is it free somewhere?
This is RadioMobile (freeware):
http://www.cplus.org/rmw/english1.html
Best regards,
Christian Meis
Is that mini-pci ? you can just insert into pci slot ?
You can insert miniPCI into PCI slot using miniPCI-PCI adapter
for. ex:
http://www.mikrotik.com/Documentation/ia_mp1.pdf
just insert mPCI to adapter and stick adapter into PCI slot
You can find other adapters, cheaper ones, but if you want only one/two pcs of them, buy mikrotik ones, they are the good quality on market.
We are using other, but we need some time for find them, test, we’ve tested about 5 different mPCI-PCI adapters, some of them have problems… (long story)
JP,
Are you still following this practice and do you still consider it helpful?
thanks/regards/ldv
if you are talking about JP using glue, i do this with the hot glue gun and U.fl’s to a 8602…32 of them serving clients for about 1 yr now and so far no issues
