Before anybody asks, RouterOS is not affected by the Poodlebleed exploit.
This is the first time I see such active approach from mikrotik. Keep going forward with this. I appreciate that.
I hadn’t heard of it, but now that I’ve seen it, I’m almost wondering how it hasn’t been found sooner (like, as soon as SSL 3.0 became an easy to decrypt protocol). I mean, OBVIOUSLY, if you have a control over the network between client and server, you can drop some of the connections. I never knew SSL/TLS tries to make several connections at the handshake. I thought it’s one connection with packets back & forth (which would be more secure, but then again, I can also see how legacy applications might be broken with that approach, and thus how clients ended up doing the “downgrade dance”).
OK, onto MikroTik…
When you say MikroTik is not affected, it’s not affected because…
- You have SSL 3.0 (and older) disabled or
- You use an OpenSSL version with TLS_FALLBACK_SCSV support, and have that enabled
What about SSLv3 based SSTP? Is affected?
It only uses TLS and that is not affected.
