Poor indoor signal
Hello all,
I’m trying to setup a indoor access-point. However, the signal is very poor. I can’t connect my laptop from 3meters.
I’m using a 2.4-5.8GHz Swivel Antenna with cable and U.fl connector.
Any idea?
[admin@MikroTik] > /interface wireless print
0 name=“wlan1” mtu=1500 mac-address=00:0C:42:61:C0:F2 arp=enabled interface-type=Atheros 11N mode=ap-bridge ssid=“” frequency=2412 band=2ghz-b/g/n
scan-list=default wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default compression=no
1 name=“wlan2” mtu=1500 mac-address=02:0C:42:61:C0:F2 arp=enabled interface-type=virtual-AP master-interface=wlan1 ssid=“NEMVEM” wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
[admin@MikroTik] >
Crack the case and make sure the antenna cable is connected and seated properly.
