one of my client using RB800 with 1 wireless card + omni 15db outdoor antenna for his main AP.
this RB800 connected to RB1100AHx2 as main router.
when he decide to change the above RB800 with Groove A51HPn + omni 15db outdoor antenna, the performance suddenly drop; the connection mostly intermittent.
the total client serve are less then 20 devices (notebooks and gadgets).
the configuration between the above RB800 and Groove are exactly the same..
/interface bridge add name=bridge1 protocol-mode=rstp
add bridge=bridge1 interface=wlan1
/interface wireless set [find name=wlan1] band=2ghz-b/g/n frequency=2412 mode=ap-bridge ssid=“Main AP” wds-default-bridge=bridge1 wds-mode=dynamic-mesh wireless-protocol=any disabled=no
/system identity set name=“Main AP”
why the performance suddently drop when he use groove ? is that because of different ram and or processor ?
the connection from all the devices to the groove seems to be ok. but the connection to the internet are intermittent.
when groove replaced with rb800+r52h, the intermittent disappear. so the problem should be on groove.
when groove restarted, the performance seems to be ok for the first 5 minutes only, the rest always intermittent; such as the page loads never finish.
sorry for late response…
a few weeks ago i had a chance to test the connectivity again even if by remote.
once the groove turned on, i found 30 subscribers connected into the divice (from /inter wire regi print)
than, all the connection from clients become intermittent.
here is the screen shot captured
192.168.101.66 is the groove as AP wire connect with RB1100AHx2
192.168.101.67 is another groove as AP WDS
so the ping from groove to groove itself having too many time-out.
so i think the problem is from the groove wireless card itself that can not handle 30 clients at the same time.
