I am hoping that someone can help me figure out some performance issues that I am running into with some extremely poor performance I am getting on a new CRS125-24G-1S-2HnD-IN.
My ISP in my area recently upgraded to 300Mbps/20Mbps from 100Mbps/5Mbps. I had been using a RB2011Ui before the upgrade, but I used this as an opportunity to get the entire network to gigabit.
I have tried multiple configurations with the CRS125 and, at best, I am getting 20Mbps/20Mbps.
Right now I an running an almost completely default configuration. The only thing I have modified are some DHCP options. When I am wired directly into the cable modem, I do get the speeds that I expect. When I plug into the CRS125, my speed drops dramatically. All of the line quality tests are coming back clean and the cable company has validated the configuration on their end. The only non-optimal thing that I am dealing with right now is that I am double natted when I am running through the CRS125 so I can wire into the cable modem. I had the modem running in bridge mode but I changed it back so I could test connections on the outside of the router.
The only thing that I haven’t tried yet is turning fastpath on. Even without that, though, I think I should be getting higher speeds than I am currently getting.
Can anyone point me in a direction of something else to try? I really don’t want to give up and go with just the cable modem.
Thanks,
Matt
