Hi guys,
we have a RB3011 connected to a CCR1036 through a dedicated fiber MPLS connection (capped to 30/30 Mbps).
Latency from RB3011 to CCR is about 3 ms, no jitter, no packet loss.
MTU is 1500.
Between my two routes I have configured a GRE tunnel.
/interface gre
add allow-fast-path=no !keepalive local-address=10.38.16.6 mtu=1500 name=gre-tunnel remote-address=10.30.1.6
When I make a bandwidth test on the L3 network, I obtain about 29 Mbps.
If the MTU of the link is 1500, then the MTU of the GRE tunnel will be less, due to overhead - 24 bytes smaller. Try again, but with packets of 1476 bytes.
Thank you Paternot.
Actually, using option “remote-udp-tx-size=1476”, the result is about 29.4… much better!
So, it must be a fragmentation issue, but now I can’t understand why if I check fragmentation through the tunnel, it seems unfragmented up to 1500 bytes.
For example:
ping 8.8.8.8 do-not-fragment size=1500
It replies OK, while trying with 1501 it says:
packet too large and cannot be fragmented
Why does it appear that GRE tunnel MTU is 1500?
Do I have to change manually MTU size on the GRE settings to 1476? (now it’s 1500).
Because the traffic inside the tunnel itself is not fragmented - the tunnel is. Like this:
Tunnel MTU is 1500.
Ethernet MTU is 1500 too.
GRE has an overhead of 24 bytes. So, a packet (inside the tunnel) of 1500 bytes results in an outside world packet of 1524 bytes.
Ethernet can only transmit 1500 bytes. So, the 1524 bytes packet is broken in two: one with 1500 bytes (header and payload) and another with 24 bytes of payload - plus header.
When you cut the MTU of the GRE tunnel to 1476, we have this:
Tunnel MTU is 1476
GRE has an overhead of 24 bytes. So, a packet (inside the tunnel) of 1476 bytes results in an outside world packet of 1500 bytes.
1500 bytes is the ethernet MTU, so a single packet is sent.
Remote endpoints aren’t aware of the GRE tunnel in between them , and its MTU.
So they’ll negotiate a too big packet size on tcp session setup.
And routers will start fragmenting oversized tcp packets (ie most packets).
When DontFragment bit was set, router will sent back “fragmentation needed” icmp response, and packet doesn’t reach remote side
So in short: yes, do use mss-clamp.
Luckily, most traffic is tcp, large udp packets still require fragmentation
