Hi!
I have Mikrotik CRS312-4C+8GX switch and I faced with next issue:
config:
# model = CRS312-4C+8XG
add ingress-filtering=no name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=VLAN_100 vlan-id=100
add interface=bridge name=VLAN_200 vlan-id=200
add bridge=bridge ingress-filtering=no interface=ether1
add bridge=bridge ingress-filtering=no interface=ether2 pvid=200
add bridge=bridge ingress-filtering=no interface=ether3
add bridge=bridge ingress-filtering=no interface=ether4
add bridge=bridge ingress-filtering=no interface=ether5
add bridge=bridge ingress-filtering=no interface=ether6
add bridge=bridge ingress-filtering=no interface=ether7
add bridge=bridge ingress-filtering=no interface=ether8
add bridge=bridge ingress-filtering=no interface=combo4
add bridge=bridge interface=combo1
add bridge=bridge interface=combo2
add bridge=bridge interface=combo3
add bridge=bridge interface=VLAN_100 pvid=100
add bridge=bridge interface=VLAN_200 pvid=200
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface bridge vlan
add bridge=bridge untagged=combo4 vlan-ids=1
add bridge=bridge tagged=bridge,ether1,ether3,ether4,ether5,ether6,ether7,ether8,combo1,combo2,combo3,combo4 vlan-ids=100
add bridge=bridge tagged=ether1,ether3,ether4,ether5,ether6,ether7,ether8,bridge,combo1,combo2,combo3,combo4 vlan-ids=1000
add bridge=bridge tagged=ether1,ether3,ether4,ether5,ether6,ether7,ether8,bridge,combo1,combo2,combo3,combo4 untagged=ether2 vlan-ids=200
/interface ovpn-server server
set auth=sha1,md5
/ip dhcp-client
add interface=VLAN_100
add interface=VLAN_200
/tool romon
set enabled=yes
speed between VM’s in the same VLAN (VLAN100->VLAN100, or VLAN200->VLAN200) is perfect - almost 10GB/s
but if I want to route traffic between VLAN’s like VLAN100->VLAN200 or VLAN200-> VLAN100 it limiting by 1GB/s for the same phisical mashines with allowing to have 10GB/s for the same VLAN,
could someone help me to understand what I am doing wrong?
