Hello, I have two Grooves, 3.5km apart, and everything was working perfectly until recently. I used to get about 80-90 Mbits on test, and now I get 30 Mbits, barely… tried changing channels, went through all of them, nothing helped. The signal is the same as it was, excellent, and all led lights are on, nothing was touched on the hardware, the cables have been replaced… I used to get full 60 Mbits from my ISP to the other location, now I only get 30…
I am thinking that maybe one of the Grooves has a hardware failure… I don’t know if it was a reason for this problems, but I upgraded to the latest RC and noticed that, but maybe the problem was before, tried reverting to older ROS versions but the same problem continues…
Rates fluctuate and even go to 150Mbps-40MHz/1S/SG
