im using since 6 Month the CCR1016 (v6.6 now), just BGP and routing some /22 Prefixes over VLAN to Internet. No other config.
If im gonna test the TCP Performance it’s just 3 - 6 MBit(!) But there are 1 GBit (per Direction) available.
Working as Excepted: (Networks are just sample, im using public IP Space)
Ether 1: Switchport 10 (Net: 10.0.0.1/24)
Ether 2: LACP Bond 1 (Net: 10.10.0.1/24)
Ether 3: LACP Bond 1 (Net: 10.10.0.1/24)
Ether 4: Uplink (Public Transfernetwork IP)
if im using wget from ether 1 to LACP (and reverse) im getting 120 MB/secs BUT if im use wget from Home DSL (100 MBit Down) my CCR just sends 3-6 MBit/sec. But if im download from external into my Servers behind the Router im getting nearly 1 GBits Fullspeed.
Has someone else these Problems? Im asking because MikroTiK isnt able to fix this issue since over 4 Month.
I do not see how original question can help you to resolve the issue.
Please contact MikroTik support (support@mikrotik.com) with detailed description about your setup and way how performance is tested. CCR performance is much better that listed at your results.
