Poor throughput
Hi guys,
I have two zotac mini PCs connected to ports 2 and 3 of a 750GL … The ports are now configured so that they are both master ports and belong to the same bridge interface. On one of the PCs I have iperf running as a server, and on the other I run iperf as the client and I see around 560Mbps, which to me already seems lower then the supposed 1Gbps. However if I set the bridge to use-ip-firewall this drops to 177Mbps! I have only added 1 ip firewall filter rule, which identifies packets on port 80 and adds a new-packet-mark.
Am I doing something wrong, or is this normal behavior?
Cheers
