Poor VPN (SSTP,PPTP,L2TP) performance over mobile PPP
Most of the work I do on Mikrotiks is related with VPN connections over mobile (2g/3g) networks. The situation as I observed it is worrying me. Let’s say we have a main router connected to the internet over FTTH 100/100mbit link. On the other side we have numerous routers (mostly 411, 411U and 411UAHR) connected through mobile 2g or 3g networks to the internet, using different modem brands and manufacturers (Sierra wireless, Novatel, ZTE, Huawei,…). Also those remote routers establish some type of VPN to the main router (SSTP, PPTP, L2TP).
Mostly all remote routers connect to VPN and I can see themn as connected on the main router. The problem shows itself when I start to produce network traffic over VPN. Very little data needs to be sent - around 15kb every 15 minutes. The VPN tunels disconnect and a lot of times they reconnect back but sometimes they dont and in logs on main router I see it came to authenticated, but when it should say what IP the remote router should have it disconnects… and so on. I have tested MTU from 1420 - 1500 and I saw no difference. The VPN links just aren’t stable (or I don’t know how to make them more stable). :frowning: If I use APN from mobile provider I can see some latency, but never a disconnect. The 2g/3g signal on all locations is between -65dBi and -90 dBi.
One of those remote locations is my workshop where I also have a test 3g link (and PPTP VPN) to main router. It experiences the same simptoms as all other remote routers. But then I use my android phone and connect it in my computer via cable or wireless, using the same SIM card (it doesnt matter which) and I establish a Windows PPTP connection to Mikrotik main router it works as it should. I get no disconnects, I can even send and receive larger files (100MB+), again without disconnects.
WTH? :slight_smile:
Any help apreciated.
br,
bysaRD
I’m the only one with this problem?
Such a technical question, can u please tell me which vpn service are you using theses days ?? If you are looking for a good VPN service then I would suggest that you visit a review website like http://www.bestvpnservice.com/
I know that my Verizon 4G link is constantly going up and down according to there being traffic or not. I can’t get RouterOS to keep the PPP connection open constantly (or open it consistently). I wouldn’t be able to run a PPTP link over it with how unstable it is. The only reason its tolerable at all is ~some~ connectivity is better than none.
If I use the same USB 4G modem on my desktop the link is solid, with no problems at all.
I would submit it as a bug to technical support.
I’m too facing the same problem. It’s just not stable enough, it keeps dropping and sometimes takes several days to re - establish connection. Signal level is in the 60-70db region.
Have you found a way to make it stable?
